Landscape material attribute doesn't work
   5189   10   4
Hello.
So just a quick question.
Does anyone have problems assigning material attribute on UE4 Landscape?
(I am using Houdini Core 18.0.618 and UE 4.24.3.)
I have a material attribute assigned on my HDA with a link to a material in Unreal 4.24.3.
The HDA generates a Unreal landscape and assigns masks and erosion.
The HDA works except it doesn't apply the material anymore. (Worked in previous version of Houdini)
I can however apply it in manually in Unreal and it works, but not using the material attribute in Houdini.
Edited by Mindark - 2020年10月29日 05:37:06
It doesn't work for me either. I always need to drag and drop it manually within unreal.
I cannot find anything on google searches either.
I will contact customer support on this.I can give you an update if I get an answer.
Mindark
That would be great! I use the latest Houdini with the latest v2 engine.
Edited by ChrisGG - 2020年10月29日 07:04:48
Oh!
I wasn't the only one!
I did a bug report, and they told me to post my answer here and check it out. Please let me know when you get an answer. Thank you.
Edited by FUNNYPAW - 2020年10月29日 20:55:36
オンライン
Same here! (and I also made a bug report)
Yep, experienced the same.
Also reported it.
Hopefully they'll fix it soon.
Came here looking for this, and yeah, same issue. Even when using a SideFX made example HDA that their video showed working, no longer works (like the apocalyptic ruin demo)
So , I haven't got it to work with the latest plugin either(4.25-v2)
All my other assets are working but not terrain.
I will try Unreal 4.26 preview 7 and check there…
Jonteman
@Jonteman, let us know if you get the plugin up and running in the preview 7 from the launcher. I've had no luck compiling the plugin for it
FYI. this was fixed in 18.5.406
