HDA Generates output for every node
   1991   2   0
Houdini HDA generates outputs for every node inside the HDA.
I reinstalled everything but still happens.
And it happens with every HDA now.
Any Ideas?
Unity 2020.1.10f
Houdini 18.5.499
Edited by ThomasSpaceflower - 2021年3月16日 16:14:29
Hi, I've actually never heard of this happening before. Can you submit a bug report with the HDA/project in question? Also, it looks like the outputs are being generated in the HDA_Data gameObject. That doesn't look normal.
Edited by anthonyt2 - 2021年3月19日 17:12:14
Appending to my earlier answer, A part should only have HDA data as its parent if:
- The parent is the asset root
- The object is instanced but not visible.
- It is a curve
Maybe make sure your instances are visible?
