Tracking down script with Hotkey???
   2337   2   0
I created a script and set a hot key to it, and want to transfer it to a new machine but I can not find where it is looked though the hotkey editor and did not see it, and that combo is not used according to the hotkey map. I know it works because it outputs to the console... any other ideas on where/how to find it?
I believe I put it in a toolbar but I am darned if I can find it.
It should be in your home dir in the houdini18.5 folder called
Houdini.keymap.overrides
For me this would be:
$HOME/houdini18.5/Houdini.keymap.overrides
Sean Lewkiw
CG Supervisor
Machine FX - Cinesite MTL
mrCatfish Thank you, that worked! Also discovered that it shows up when you export the hotkeys...
