Houdini on Linux via VirtualBox
   2691   4   2
Has anyone successfully run Houdini on Linux via VirtualBox?
I'm developing on Win, and sometimes need to test it on Linux. VirtualBox is way more convenient then dual boot.
I am getting this crash when running Houdini 18.5.672 on Ubuntu 20.04 via VirtualBox 6.1
Traceback from 5944 ThreadId=0x7f3f70793cc0
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
__funlockfile <libpthread.so.0>
I might try vmware, but I have a feeling its the lack of "proper" gpu device that is causing the trouble.
Michal Tas Maciejewski @ www.vfxtricks.com
Hi, did you try to install opencl?
mihatsu
I tried, also I have HOUDINI_OCL_DEVICETYPE=CPU.
Hi Michal,
I've managed to get houdini working under virtualbox. I'm using mint linux (19.1) and houdini 18.0.532 (its an older setup)
i wasn't able to get it going with virtualbox's gpu acceleration, instead (i think) installing mesa for software opengl
sudo apt-get install mesa-utils
it's slow and glitchy, but for occasionally testing some pipeline stuff it fills my needs.
cheers,
chrisg
Edited by doctorbob - 2021年9月5日 23:17:26
ahh, thanks for directions. Here is what I have learned so far.
VMware provides overall better experience compared to VirtualBox.
On VMware I get OpenGL4.x compared to OpenGl3.x on VirtualBox - out of the box, without installing extra drivers.
Both running Mesa in software mode.
On VMware with OpenGL4.x I can run H18.0, but any 18.5 is crashing.
I will try to make a ticket with SESI, but not sure if they will pursue unsupported OS config.
It used to work not so long time ago, hopefully it can work again.
cheers!
