Points on animated mesh
   1776   1   1
Hello - Would someone be able to help?
Is there any way to scatter points on a remeshed geometry that is animated and changes per frame, with out all the points jittering all over the place.
I know the common ways to do this using Attrib Interpolate and Point Deforms, but in this particular instance neither of these will work - I think primarily because the mesh splits onto two separate meshes.
I have created a work-around, but it's a bit convoluted and just wanted to check I'm not missing something obvious.
Below should be a gif of the remeshed output
Also a gif of the work-around output (WIP)
And also attached the Houdini file
Any thoughts greatly appreciated
Edited by Hatchery - 2021年10月17日 08:12:52
Test.hiplc (164.4 KB)
Love Houdini
Slightly different question.... is it possible to take the above, spacifically the copyied-to-point spheres shown in the animated gif and use this with vellum to have them ballon out to fill the space? can you animate points/mesh and simulate overtime?
Applogies Vellum is not somthing ive used yet so just wondered if this was even possible,
Love Houdini
