I have a point cache sequence where each frame is (subjectively) similar in geometry, though not in topology. I'm looking for a way to 'slomo' the sequence, similar to the way optical flow would be used on images.
Would converting to SDF then using VDB Morph SDF be an option?
I would need to be able to bake then morph / blend between colour too
interpolate / morph similar meshes
1553 2 2-
- mrboni
- 43 posts
- Hatchery
- 141 posts
- mrboni
- 43 posts
Hi Hatchery
Thanks for this
An issue with this is it's not necessarily possible to achieve the full 'lerp' to the other geo. Did you try with more complex geometries?
Another issue is the lerp should happen over the whole geo simultaneously, not just when a distance threshold has been exceeded.
Thanks for this
Edited by mrboni - 2022年5月17日 11:07:49
