PDG Asset Link Top Node default selection settable?
   2757   2   1
Is there a way to set the default selection of the TOP Node? I'm working through a terrain tutorial and it is defaulting to the terrain generator so if I Cook Output, I get my final terrain but also the terrain generator output in the scene, which shouldn't be there since it is just a step in the process. So I'd like to be able to set the default selection to the PIPELINE_OUT node somehow.
no I dont want you.png (50.9 KB)
how to make default selection.png (50.1 KB)
you should name your node with HE_ as prefix, only these will appear on Top node list
and you can use HEngine data, to autocook specific nodes of your PDG
grumiauxl
Fantastic, thank you
