Curve & Sweep Disconnect Issue
   2286   4   1
Hello, I've got a problem with a spline/curve in Houdini.
I want to take a curve and run it through a sweep node but everytime it has a break in it, I think it has something to do with the direction the points are facing, because when the sweep is run and geometry added you can clearly see a rotational difference between the top section and the bottom section. (as the curve was made from two separate curves originally)
I deleted all attributes and groups to isolate the issue, the only thing on the geometry spreadsheet are the point positions and I made sure the whole curve is one whole piece.
I attached the hip file for you to inspect.
Any help would be appreciated.
Edited by ibuildspace - 2024年3月11日 07:07:15
HouSplineIssue.rar (55.3 KB)
www.ibuildspace.com
Hi!
It seems that your spline is still two separate polygons there. With an additional join node you can combine them. that should solve your problem!
オンライン
It's still two curves. Prepend a polypath or fuse and join (set to 'only connected') nodes before sweeping.
@Konstantin & @recomberlin Thanks for having a look.
I had previously fused the curve, so I didnt realise another operation was required to make sure a curve was one complete object so thanks for pointing that out.
I did what you said and that fixed the part I showed in the image, however the top parts are still disconnected even when I append a polypath or join.
Edited by ibuildspace - 2024年3月11日 12:54:28
www.ibuildspace.com
Grab an Lsystem sop (which is what I used for the top part) and plug it into a sweep.
Perhaps this is just a limitation of the sweep node? Maybe it just cant deal with the geometry at branching points?
If thats the case, Any ideas on how to properly approach this?
I could voxelise after the sweep to have a mesh without any disconnected parts, but that a, slows things down and b, I want to keep the clean uv's I already have.
Edited by ibuildspace - 2024年3月11日 10:24:04
www.ibuildspace.com
