Can pop fluid exhibit high viscosity like honey ?
1037 0 0-
- 910297565
- 12 posts
Hi guys, I was wondering if POP fluid can exhibit very high viscosity? I want to make a small honey ball (0.3*0.3) with POP (I know FLIP would be better, but I was just wondering if the POP solver can do so). So, I've set the constraint iterations in the POP fluid node to 100 and constraint stiffness to 500, and the particle separation is 0.01. but when viscosity is set to 3 or larger, the particles exploded. So, can POP fluid exhibit high viscosity? BTW, which parameters are used to set surface tension? Thanks for any replies.
