Hello all,
I created a object I apply a volume shader on it and I want to use my alpha texture to guide the density of the volume density(from 0 (no density) to 1 (full density). I am using renderman and houdini, I tried the to plug and to play with attributes but I have no idea how to proceed. thank you
density from texture
346 3 0- JJBBK
- 5 posts
- Honza Topinka
- 11 posts
- JJBBK
- 5 posts
Hi Honza thank you for your reply,
The Volume is the shape of the surface object.
I want to use a texture as a alpha, the same way you plug a texture into the opacity of your shader.
I am using renderman, the volume shader doesnt reconise the uvs of the object. I tried to use the projection but I didnt manage to make it work.
is ther a way to sore the Cd with a attribut from map > call it inthe shader system through a primvar and use it to drive the density ?
thanks
thanks
- Honza Topinka
- 11 posts
Aah, I see. I actually misunderstood, sorry. I guess building to volume from geometry with the texture as an attribute driving the density is not what you want...
Also I don't know or have Renderman, but in Karma I could kind of plugin a texture into a shader with point cloud lookups. Once again probably not exactly what you want, but maybe closer? There has to be something similar in Renderman.
A terrible answer, I know
File attached
File attached
Edited by Honza Topinka - 2024年5月3日 10:12:33
