How to read Multi-layer EXR images in python with OpenEXR
   3221   2   0
Hey all! I'm working on a python tool that lets you view Multi-layer EXR images. I'm unable to use OpenImageIO due to technical support reasons. So I'm stuck with using OpenEXR. I've been able to read Multi-Layer EXR images from Blender and Maya but It seems Houdini has a different header format. If anyone knows how can I split the multi-layer data into seperate PNGs, or knows any resources that could help, please let me know!
cjhosken
Hmm, I've been wondering the same thing. I wonder if Mitsuba might be able to pull it off. I'll let you know what I find out.
Hi
imports: take out what you do not need.
My image was 1024x1024,if you see this magic number somewhere
I copied this from a more large code, hope not miss something (did not try)
import OpenEXR
import cv2
import numpy as np
import imageio
import ast
import os
import json
import codecs
import csv
exr_filename = "path_to_your_exr.exr"
# Load the exr file into memory
exr_file = OpenEXR.File(exr_filename)
# the exr header contains usefull information about the EXR file
exr_header = exr_file.header()
print(exr_header)
# The manifest gives information about the Cryptomatte data.
# If you dont need cryptomatte skip it
# the '3ae39a5' may be different for you, but you can see it in the printed header
exr_manifests = ast.literal_eval(exr_header['cryptomatte/3ae39a5/manifest'])
print(exr_manifests)
# The parts contains all the layers we need
# ALL LAYER NAME COMES FROM THIS
exr_parts = exr_file.parts
print(exr_parts)
# GET DEPTH
depth_part = next((part for part in exr_parts if part.name() == "depth"), None)
depth_pixels = depth_part.channels['depth.z'].pixels
depth_image_filename = "path_to_your_depth_file.tif"
imageio.imwrite(depth_image_filename, depth_pixels)
# GET NORMAL
cameranormal_part = next((part for part in exr_parts if part.name() == "N_camera"), None)
cameranormal_pixels = cameranormal_part.channels['N_camera'].pixels
cameranormal_filename = "path to your normal file.tif"
imageio.imwrite(cameranormal_filename, cameranormal_pixels)
# GET COLOR
color_part = next((part for part in exr_parts if part.name() == "C"), None)
color_file_name = "path to your color file.tif"
color_pixels =color_part.channels['RGBA'].pixels
imageio.imwrite(color_file_name, color_pixels)
# change gamma for color
postprocess_pixels = color_pixels.copy().astype(np.float32)
gamma = 2.2
postprocess_pixels = np.power(postprocess_pixels, 1.0 / gamma)
# Save postprocessed image as 8 bit RGB
postprocess_pixels_to_save = postprocess_pixels.copy()
if postprocess_pixels_to_save.ndim == 3:
    postprocess_pixels_to_save = postprocess_pixels_to_save[:,:,:3]
postprocess_pixels_to_save = np.clip(postprocess_pixels_to_save, 0, 1)
postprocess_pixels_to_save = postprocess_pixels_to_save * 255
postprocess_pixels_to_save = postprocess_pixels_to_save.astype(np.uint8)
# save postprocess
postprocess_file_name = "path to postprocessed file.png"
imageio.imwrite(postprocess_file_name, postprocess_pixels_to_save)
# Get the cryptomatte part
# I only used it for bit mask!!!!!!!!!!!!!!!
cryptomatte_part = next((part for part in exr_parts if part.name() == "CryptoObject00"), None)
cryptomatte_pixels = cryptomatte_part.channels['CryptoObject00'].pixels
#only the red channel matters
cryptomatte_pixels = cryptomatte_pixels[:, :, 0]
# Extract segmentation from cryptomatte
# change the 'xxxxxxxxxxxxxxxxx' to a grayscale value for every cryptomatte name
cryptomatte_segmentation = np.zeros((1024,1024), dtype=np.uint8)
for key, hex_value in exr_manifests.items():
    # Convert hex string to integer
    target_int = int(hex_value, 16)
    # View the float32 array as uint32 for direct comparison
    data_uint32 = cryptomatte_pixels.view(np.uint32)
    # Create a boolean mask where the uint32 values match the target integer
    cryptomatte_mask = data_uint32 == target_int
    cryptomatte_mask = cryptomatte_mask.astype(np.uint8) * 255
    cryptomatte_mask = cryptomatte_mask != 0
    cryptomatte_segmentation[cryptomatte_mask] = xxxxxxxxxxxxxxxxx
# Save Cryptomatte segmentation
cryptomatte_file_name = "path to your semantic segmentation mask.png"
imageio.imwrite(cryptomatte_file_name, cryptomatte_segmentation)
