resize a cube through a Vex Function
   1579   6   2
Hello there.
I am really sorry for the ultra noob question:
I have a cube, that I would like to resize with a VEX function
float test = ch("../transform1/sz");
if(ch("../line1/dist") <= 2)
    @scale = set(1.0,3.0,4.0); //resize box. not working
    @sizey = 3.0; //size box. not working
    @Cd = set(0,1,0);//debug purpose. if green, code is compiling
    test = 3.0; //going through a transform node doesn.t work either...
else
    @Cd = set(1,0,0);//red. if red, code updates
I don't understand why I cannot resize my cube....
thank you for your help
Hi
@scale is a point instance attribute that is usually used in copy to point or dop context. Use matrix transformation when dealing direct with geo (hip example below):
matrix M = ident();
scale(M, chv('t'));
@P *= M;
Edited by vikus - 2025年2月18日 11:48:16
vex_scale.hiplc (108.7 KB)
thank you for your message!
here is what I am trying to achieve ;
I have a box, that I 'copytopoints' on a line
I try to instantiate the box on every point on the line, and the amount of points on line changes depending on its length...
The problem is when I make the length of the line change, in a float way (for example : 1.43), there is either a gab between boxes (if under n.5 float value : 1.3 for example), or an overlapping geometries (if over the n.5 float value : 1.6 for example).
like the picture here :
I thought it would be easier to play with vex, but maybe there is a much easier way to play it around.
what do you reckon?
I did it with VEX
I am not sure it works tho. I will come back to report after my tests
vector toscale = chv('t');
matrix M = ident();
if(ch("../line1/dist/")%1 <0.5)
    toscale.x = ch("../line1/dist")+ch("../line1/dist")%1;
    @tx = toscale.x;
    scale(M, toscale);
    @P *= M;
else if(ch("../line1/dist/")%1 >0.5)
    toscale.x = ch("../line1/dist")-ch("../line1/dist")%1;
    @tx = toscale.x;
    scale(M, toscale);
    @P *= M;
Edited by lostshun - 2025年2月19日 02:33:26
You need to compute the ratio between length and (point amount(n) - 1 = (gap amount).
ratio = length / (n - 1). As long as the cube is uniform that should work.
Put some examples. You dont need 'vex', could also use transform sop with expression.
Edited by vikus - 2025年2月19日 02:53:10
vex_scale.hiplc (124.8 KB)
Use the chain SOP with this exact functionality.
vikus
oh my god! sweet!
that's the answer you are looking for! thank you so much!
mawi
oooooohhhh! it works so easily! and yes, this node is exactly what I was looking for, in such a simple way!!
thank youuuuuuu
