Hey guys,
Is there any way to move or offset a texture along a curve while keeping the curve normal direction?
Basically, I want the texture to slide along the curve ( breaking or rotating...
Any suggestions would be appreciated.
Copernicus - offset a texture along a curve
816 4 1-
- Milad Savar
- 34 posts
- Milad Savar
- 34 posts
- Gaalvk
- 42 posts
- Milad Savar
- 34 posts
Gaalvk
In theory, we'll distort the UV, and the texture will follow it. If you want to deform the texture in Copernicus, you'll need to use distort and apply a pre-calculated normal map to the curve.
actually distort doesn't work , [ destroy the Texture in each time-step )
just put there show the Curve Direction work ..
but i need offset texture along the Normal , which i stuck this problem ;(
Edited by Milad Savar - 2025年12月16日 13:09:19
- Gaalvk
- 42 posts
