Megascans LiveLink in H21
   2903   7   2
Like most of you probably know, MSLiveLink used to work in Houdini up until H20.5 but since H21 it did not work anymore.
Even though Quixel Megascans is migrated to Fab, the Bridge App still works and personally, I prefer Bridge to browsing through all the paid stuff in Fab.
So what I did to fix it is not very complicated but I wanted to share that here with the community.
The issue is the fact that H21 switched to Qt6 and so PySide2 is not available anymore.
Since the python scripts in the MSLiveLink plugin use these you get errors.
The fix is easy:
If you have your MSPlugin installed you have to go to
MegascansBridge\support\plugins\houdini\4.6\MSLiveLink\scripts\python\MSPlugin
In there you'll find a bunch of .py files that all call on each other.
First MainWindow.py:
In the first lines you'll see this:
from PySide2 import QtGui
from PySide2 import QtCore
from PySide2.QtWidgets import QLabel, QWidget,QApplication, QVBoxLayout,QMainWindow
Change those to PySide6 and this file is done.
This file invokes OptionsUI.py and USDUI as well and later SocketListener.py as well, so we need to check all those as well but to be short: in all the .py files you find in this directory, scan for PySide2 and change it to PySide6
But that's not all.
In USDUI there are calls to QRegExp. This is deprecated since Qt5.15 and should be replaced by QRegularExpression.
The line(43) containing that code will look like this after you changed it:
self.refpathRegexp = QtCore.QRegularExpression("+")
There is also a call to QRegExpValidator and that one has also been replace, in this case by QRegularExpressionValidator
So, line 44 will be this:
refpathValidator = QtGui.QRegularExpressionValidator(self.refpathRegexp)
Save all the files, and lo an behold, your Megascans Livelink works like a charm again.
Hope this helps
Rudi
Thanks for the advice Rudi. Worked for me. Using Windows 11.
~joel
オンライン
Thanks for sharing! Worked for me as well
Thank you so much!
I know it's been a minute, but would you happen to have an example screenshot? I'm not very familiar with python but currently attempting to update this path in my Windows file.
ninethtale
What part would you like the screenshot for? The edits are text-only, and I wrote the changes. Maybe I do not understand what you mean. Where are you stuck? Maybe I can help if you pinpoint where it is not clear.
It does not work for me first so I updated it and it works now I guess
check the attachment
MSLiveLink.rar (490.5 KB)
RudiNieuwenhuis
The fix is easy:
But that's not all.
Hope this helps
Rudi
Thanks for sharing with us. works great !
