ubuntu 7 64 bit
Houdini-9.0.719 64 bit
Default preferences
I use Rop output driver for save objects. After x frames Houdini use all my memory.
Only Houdini restart can clean memory after bake (new scene and clean cache doesn't work).
cheers
BUG: Houdini don't clean memory after save objects
3618 4 0- fryga
- 19 posts
- wolfwood
- 4270 posts
- fryga
- 19 posts
- wolfwood
- 4270 posts
To accommodate the heavy geometry Houdini allocates the 2gigs of RAM from the system. Once that it is done it belongs to Houdini until the program is closed. Hitting File -> New doesn't actually restart Houdini, it just clears all the nodes within the session. Since its the same Houdini session it still owns the 2gigs.
- fryga
- 19 posts
right!!
When I bake this sphere Houdini works fine.
Something must be wrong in my network because it use 8 gb of ram and Houdini don't clean memory after
Can you look at on this hip:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=9949 [sidefx.com]
All works normally ??
Thanks!!
Thanks!!
