Python Use SOP edit node... How can I set apply.?
   2004   2   0
hello… TDs….
I am Working on 3D R&D for ANi in seoul…
It's make me cry…
python script is below…
First. make poly cube then
>>> box_ = hou.node('obj/box_object1/box1')
>>> edit_ = hou.node('obj/box_object1').createNode('edit')
>>> edit_.setFirstInput(box_)
>>> edit_.setDisplayFlag(True)
>>> edit_.parm('grouptype').set('points')
>>> edit_.parm('group').set('1')
>>> edit_.parm('tx').set(2)
>>> edit_.parm('apply').set('???' )
so.. I can't find right “apply” set value..
I want to same resolts of “Commit Transform/Peak Chnage” Button. in Edit
with Python script…
please tell me what is right value in set ?
thank you…
To execute buttons you need to use hou.Parm.pressButton().
edit_.parm('apply').pressButton()
If you are wanting to be modifying lots of points in a script, a better solution might be to use a Python sop instead of edit.
It's working…
That's sounds great…
I will try python sop….
thank you…
