Hi all
I am looking to convert a volume field generated in pyro fx to a surface.
The problem I am having is that I end up with a lot of extra info due to number of fields involved. Does anyone know how to use VOPs to strip out only the density field and use that to generate a mesh? I have unsuccessfully tried iso-offset, iso-surface and volume convert
I have included an example file so you can see what the hell I'm talking about
cheers
convert volumes to surface issues - VOPS???
5877 2 0- megasets
- 85 posts
- mawi
- 242 posts
glassman3dVOPS can only handle points and each field is a primitive.
Hi all
cheers
Create a delete SOP set to primitives and delete non selected.
MMB click and look what prim number is density(It should be 0).
type 0 in pattern.
Pipe that into a volume convert and increase the iso value.
Edit… There is a volume VOP for fields but I dont think it can delete volumes or generate a mesh.
- megasets
- 85 posts
