fur procedural
   4945   5   0
hi
i have a procedural fur object;when i hit render i have this message in houdini console
“mantra: /obj/model_geo: Procedural generated out of bounds geometry”
and i see this message only when i apply the cvex to the procedural fur guides.
anyone can help me?
najar
hi
anyone can help me?
This can be fixed by increasing the Fur Procedural's “Expand Bounds” parameter. Mantra tests against a bounding box to determine if an object is visible. In your scene, the CVEX shader is moving vertices outside of the original bounding box. The expand bounds parameter tells mantra how much bigger to make the bounding box for each patch of fur.
thinks a lot derrick i try to make a very big bound box values but nothing change!!! :shock:
najar
Could you post a simple example file that triggers the warning message?
that helps
it work now thinks you
