Playbar, Range Slider disabled - bugged?
   858   0   0
I was trying to maximize screen space and came across "Show Range Slider" and I disabled it, saved it as default. I always felt that the playbar took up too much space, and I rarely use the Range Slider. Having the range slider disabled makes the playbar slightly thinner. But, when I relaunch Houdini the whole playbar size is bugged. The range slider is gone, but the size of the playbar is reverted back to the size of having range slider enabled. And I noticed the Keyframes Menu is missaligned as well.
I reported this bug but perhaps this is an issue with my Houdini settings only? So I ask if anyone else has noticed this? Pretty much use default settings other than:
Playbar UI - Compact
Icon Size and Layout - Small
(Red color is the new free space that results by having it disabled, but as you can see the bugged one (at relaunch) is wrong.
Added the 3 images separately if you want to overlay and switch between to see the difference.)
Edited by ChrisMANEY - 2025年4月26日 06:27:27
