HDK Tutorial Error - "Please check for valid license server"
   711   0   0
Hey everyone. I went through the HDK "Getting Started" tutorial. Followed it to the letter, and successfully built the "geoisosurface" sample. However I ran into a problem when I ran the sample. I ran the compiled executable with "./geoisosurface". The application runs, but the line "gdp.save("sphere.bgeo", NULL);" produces the following output "No licenses could be found to run this application. Please check for a valid license server host.", and writes a bgeo file containing only the text "NSJb".
I have the license server running on my machine. I can open and use Houdini as I normally would, so I'm not too sure whats going on. I'll post the specifics of my configuration below. Has anyone encountered this? Would this be a licensing issue, an issue with the build, something else entirely?
OS - Macos 15.3.2
Houdini Version - 2.5.550 Apprentice
License Admin Version - 20.5.550
HServer Version - 20.5.550
License Server Version - 20.5.584
License Server Address - localhost:1715
All Green Checkmarks in the License Server View
"Enabled Http" - No
"Is Deamon" - No
Installed Licenses - 2x Apprentice for Houdini, Renderer, and Karma Renderer
Used Licenses - 1x Apprentice for Houdini.
sesinetd - Running
HSever - Running
