Procedural Deform - Use Existing Weights
   824   1   0
I'm trying to use the deform by existing weight mode of the hair procedural node. But from what I know from the guidedeform node, it uses the primnum on the guides to reconnect them properly. But with our current setup, the primnum of the guides are modified and it would be complicated to get them in the right order again. Is there a way to use sommething else to drive the connection ? I have created an integer primsave attribute, but I don't see an option to choose another attribute.
Thanks,
To test it out I added a sop modify in the hair procedural and it turns out my primnum are okay so the problem is coming from somewhere else. Has anyone managed to make this node work ?
