Does anyone know of any help or examples for tearing cloth in DOPs? I've tried approaching it several different ways, and know there must be better ways to handle it.
The ClothStitchConstraint help suggests that the tools are there to do it, but nothing more than that…and nothing on the forums about it. I must be missing something.
ClothStitchConstraint is great for setting up seams quickly, but I can't figure out how to make the seams break when a specific amount of force is applied.
Any tips would be very helpful.
Tearing Cloth
7120 6 2-
- adam_glazier
- 41 posts
- オフライン
- kleer001
- 55 posts
- オフライン
I see two paths, one is easy and leads to success, the other is dark and shrouded in mystery and dark magic. The first path is to create the seams by hand the other is to create the seams dynamicaly.
How to actually do that, I can't say, but hopefully that was helpful, if not funny.
“If you can eat it raw you can't under cook it”
- adam_glazier
- 41 posts
- オフライン
Heheh…yeah, those path's were what I discovered. I tried doing it manually, but ran into the problem of only being able to use a limited number of constraints
Post :: Limited number of cloth constraints
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=10348&start=0&postdays=0&postorder=asc&highlight= [sidefx.com]
~adam
- adam_glazier
- 41 posts
- オフライン
- kleer001
- 55 posts
- オフライン
- adam_glazier
- 41 posts
- オフライン
- tamte
- 9416 posts
- オフライン
adam_glazier
ClothStitchConstraint should work
try setting relationship type to Two State constraint
then set Two State Initial State to Hard Constraint
and Two State Max Force to some value you want to tear the cloth
and Spring strength to 0
