Shadow VOP node in RSL surface context
   2600   1   1
I'm trying to break down a shader I did for an effect as a VOPnet and
would like to pull the shadow into my illuminance loop to be
exported as an AOV just like I used to do in mantra, but the Shadow
VOP seems to be missing in the RSL context.
Any way to do this without switching to coding? Which I would be ok to
do but given the lack of time I wouldn't attempt if not necessary +
the shader is 99% there already and instances of it are deployed in my
asset couple of times).
Inline code maybe?
Thanks,
Andras
Nevermind, had to use the shadow call through the inline vop in the illuminance loop..just like mantra (I had some screwed casting the stopped me to debug this properly until I wrote a small test shader in code).
