Can I specify the number of threads as a non fixed value?
I have 2 cores on my notebook, so the maximum value I can set this to is 2
but when i open the asset on my 8 core workstation it is using only 2 cores however it is possible to set it to 8
it would be useful if i can set it to Maximum, so it will use the maximum cores on all machines
Q/RFE: VEX Number of threads
4593 4 0-
- tamte
- 9417 posts
- オフライン
- wolfwood
- 4349 posts
- オフライン
- tamte
- 9417 posts
- オフライン
- wolfwood
- 4349 posts
- オフライン
'Generally' each core == one cpu as far as the OS is concerned.
Having threading off is the “safest” choice, so its default. Some people have run into stability problems. Also things like point clouds and pcunshaded aren't threading friendly.
I personally haven't run into problems using multi-threaded VEX OPs, but your mileage may vary.
- tamte
- 9417 posts
- オフライン
