Orient along curve - Sweep SOP style
4854 2 0-
- whalerider
- 194 posts
- オフライン
I want to instance primitives and orient them along a curve. Since I need control over each instance, I have to use Copy SOP instead of Sweep SOP. However, once instanced, the primitives are not centered on the curve (depending on how far away a curve's CV is from the curve). So how do I make sure the instances are centered on the curve? - just like the Sweep SOP does it.
- fxrod
- 133 posts
- オフライン
- whalerider
- 194 posts
- オフライン
