… when i specify start_directory.
is that as intended or a bug?
why can't both parameters co-exist?
hou.ui.selectFile() - default_value ignored
7891 5 0-
- whalerider
- 194 posts
- オフライン
- niko3d
- 338 posts
- オフライン
- graham
- 1926 posts
- オフライン
You can get it to work if you make sure your directory ends with a /.
The following will work correctly
hou.ui.selectFile(“/tmp/”, default_value=“test.otl”)
however this will not
hou.ui.selectFile(“/tmp”, default_value=“test.otl”)
It is still a bug however.
- niko3d
- 338 posts
- オフライン
- graham
- 1926 posts
- オフライン
- whalerider
- 194 posts
- オフライン
