Recording the frame number something happened using POPs
   4653   3   0
Hey,
If in SOPS I have a bunch of boxes that gradually turn red, how do I record in a attribute the frame they turned red at?
With some research I have found out that I should be able to do this by running my geo through POPs as POPs looks to the previous frames data.
I have been messing about but still am unable to get it to work. Can someone help me? My hip file is attached.
Thanks.
pops_register_activation.hipnc (52.6 KB)
you can do it with Python. not sure if you can do it with a simple expression.
iron__man
Perhaps you can run it through CHOPs via a Geometry CHOP (Animated method).
Don't worry, I worked out how to do it in POP's. Will post soon..
