Please advise
1.how I can create a standard material Mapping in Houdini ? for example, by using diffuse map and bump mapping.
2.Why Pyro renders very slow ? Do you have any way we can solve this.
3.Pls adv how to delete History in Houdini, is it the same way as Maya or XSI ?
Im beginner and need your kind expertise
3995 3 1-
- unlock
- 3 posts
- オフライン
- symek
- 1390 posts
- オフライン
unlockNot sure what is your interest, you want to know how to map uv coordinates in Houdini? Or how to apply textures and bump maps? In both cases these are basics, so I encourage you to go through some free tutorials covering these topics. You can find them on vimeo or in Learning Section of this forum (some are commercial).
Please advise
Basically you can use Basic Displacement Material from Material Pallete. Appy it on an object. Choose your maps in proper fields (Color Map, Disp. Map). and turn off “True Displacement” on Properties Tab. Done.
2.Why Pyro renders very slow ? Do you have any way we can solve this.Common mistake is using ray traced shadows instead of shadow maps. Ray tracing slows down things a lot. Avoid it.
Don't. There is no need for doing this. Keep all nodes organized, embedded in subnets or netboxes, and let then stay to your disposal in case, you decide to change something later.
If you insist to delete nodes, select the last one, and turn on Lock Flag (the red one). It will keep everything above cached in this node. You can delete now anything else.
Your hip file will quickly become terabytes big, and you wont' be able to tweak your scene anymore. but you want it, right?
Another way is to use a FileSOP to save geometry on disk, and read it back in that state.
hth.
- unlock
- 3 posts
- オフライン
- ragupasta
- 349 posts
- オフライン
