Smoke trails in explosion
   11194   4   3
I would like to achieve the effect of smoke trails which are coming from the center of an explosion. I have already the explosion simulation. I tried by emitting from particles as you can see in the attached file, but I cant get them to look as good as this: http://img152.imageshack.us/img152/5454/sa6destructionff1.jpg [img152.imageshack.us]
http://i56.tinypic.com/34fhfnb.png [i56.tinypic.com]
http://i52.tinypic.com/2njhxfk.jpg [i52.tinypic.com]
any ideas or tips?
thanks in advance.
smoke_trails.hip (1.2 MB)
I did that before and could look for a sample file if you wish but the main process was that:
-create a particle system and emit a few particles to trace the path for every tentacle
-create a second particle system using the first one as a source to create trails
-freeze the trails on the last frame using timeshift
-create volumes for every trail using volume from attribute SOP and use those volumes as fuel in pyro combustion model
-use the particles from your first particle system as a source of temperature to ignite the fuel
http://vimeo.com/user7871222 [vimeo.com]
thanks dobin for the reply, it will be great if you could find the sample file in order to study the basic setup. In my attached hip file I have done the steps 1 and 2 but I am emitting from the particles smoke. I would like to see how you do the rest of the steps.
cheers
here you go:
trailExplosion_01.hipnc (1.3 MB)
thanks a lot, I am gonna have a look and I will be back with more questions.
Just few more question related to volumes, whats the most important parameters (in rendering and shading) in order to have a high quality of fluid simulation and which renderer is the best to use PBR or Micro?
-How low can I go to the division size for the final simulation?
cheers
