using Python in attribute create with string type
   3435   3   1
I have wrote a code in python where I have a list of sentences and assign one sentence to each random point in an attribute. But it seems that in attribcreateSOP you cant use python when you are using string type, you cant use python even inside `` but you can use hscript. Am I missing something? Even when you RMB over the string parameter the “Change Language to…” is disabled.
P.S. is it possible to create a list in hscript?
nothing?
Python expressions need to be done using a keyframe and contain a return statement. They aren't compatible with the ``
For example, to create something like this you would do something like Alt + LMB on the parm to create a dummy key/expression, LMB to toggle the expression to the raw text mode (label is dark, “” appears in the parameter) and then edit it to your hearts content.
See attached.
python_str_attrib_create.hip (54.3 KB)
Thanks graham, I was hoping for your reply.
