Hi everyone,
I am building the effect of a waterdrop running on a vertical surface (bottle or whatever). I have curve as path and we raySOP I project it to the surface. Using a portion of the curve to running from the top to the bottom but what I want to be able to animate the speed, or even better using the speed mask based on surfaces normals at Y.
In the attached hip I have a test-setup with a vertical surface with noise and speed mask on its color. Wherever is black drop should travel faster and wherever is white slower. I am using two different techniques for the travelling of line with a switch. Any ideas?
Thanks in advance!
EDIT: What I am using for travelling the line is a duration, let say in 200frames finish the ride, but what I want to have is a constant speed and then be able to multiply this with an attribute as the speed mask. I would like to keep everything in SOPs if possible but I am also considering POPs.
Follow Path in SOPs with Speed Mask
2600 0 1-
- csp
- 230 posts
- オフライン
