Smart way to populate Unity GameObjects to Inputs on HoudiniAssetOTL (DigitalAsset)
   3422   1   0
Hi!
(100 is just a random number, it need to be dynamic)
So I got 100 GameObjects in Unity Editor Scene with tag “Collider”. I have made a Digital Asset where there is a merge inside and 100 inputs for all of them.
Instead of drag and drop 100 times that also will happen multiple times I want to populate it with code. I'm almost there I think. It seems like I need to convert my GameObject to HAPI_Transform. I'm stuck.
Does anyone have any idea please? :-D
this is c# code in Unity
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
using UnityEditor;
using Houdini;
public class CollectTagColliders : EditorWindow
    public static CollectTagColliders curColliderWindow;
   // public static GameObject curDGA_ColliderAsset;
    public GameObject curColliderParent;
    public static GameObject[] sceneGameObjects;
    public static GameObject curObj;
    public static HoudiniApiAssetAccessor curAccessor = null;
    public static HoudiniAssetOTL asset;
    public static HoudiniAssetOTL curOTL;
    public static HoudiniParms curParms;
    public static HAPI_ParmInfo[] parmInfos;
    [MenuItem("Spelprojekt 8/CollectColliders",false,7)]
	public static void InitWindow ()
        curColliderWindow = (CollectTagColliders)EditorWindow.GetWindow<CollectTagColliders>();
        GUIContent titelcontent = new GUIContent("ColliderTool");
        //get all scene GameObjects with tag Collider
        sceneGameObjects = GameObject.FindGameObjectsWithTag("Collider");
    private void OnGUI()
        if (sceneGameObjects.Length == 0)
            GUILayout.Label("There is no Collider Tags in scene");
        else
            if (GUILayout.Button("Print All Colliders in Debug", GUILayout.Height(40f)))
                for (int i = 0; i < sceneGameObjects.Length; i++)
                    Debug.Log(sceneGameObjects[i].name + "  index--> " + i);
            if (GUILayout.Button("Print All DGA params", GUILayout.Height(40f)))
                PlaceColliderToScene();
    static void PlaceColliderToScene()
        string assetPath = Application.dataPath + "Assets/DigitalAssets/B_addon_Collider_Parent.otl";
        curObj = new GameObject("B_addon_Collider_Parent");
        asset = curObj.AddComponent<HoudiniAssetOTL>();
        curAccessor = HoudiniApiAssetAccessor.getAssetAccessor(curObj);
        asset.prAssetType = HoudiniAsset.AssetType.TYPE_OTL;
//        asset.prAssetType = HoudiniAsset.AssetType.TYPE_INPUT;
        asset.prAssetPath = assetPath;
        asset.buildAll();
        curOTL = (HoudiniAssetOTL)asset.GetComponent<HoudiniAssetOTL>();
        Debug.Log(curOTL.prObjectTransforms.Length + " geo count!! ");
        Debug.Log(curOTL.prGeoInputCount + " geo total slot count!! ");
        curParms = asset.prParms;
        parmInfos = curParms.prParms;
            curOTL.prObjectTransforms[i] = sceneGameObjects[i];
        Selection.activeObject = curObj;
So I solved it to tag all the collider objects and with this code populate the list “prUpStreamGeoObjects”
//get all colliders in scene
sceneGameObjects = GameObject.FindGameObjectsWithTag(“Collider”);
curObj = Selection.activeObject as GameObject;
curOTL = curObj.GetComponent<HoudiniAssetOTL>();
curOTL.prUpStreamGeoObjects = sceneGameObjects;
