digital assets and relative internal references
6441 5 3-
- Sealth
- 50 posts
- オフライン
Hello again, working on creating a new digital asset, however I have some references to a chop network outside of the digital asset. When I try to create the digital asset a warning appears saying that I need to “convert these references to relative internal references”. How would I go about doing this? oprelativepath???
~the most important things in life aren't things~
- JColdrick
- 4140 posts
- オフライン
It's only a warning, since one of the typical uses of assets is to have something self-contained that does it's job, and doesn't rely on external resources in order to work. You can ignore the warning it if this doesn't bother you(but keep in mind on a production level, this sort of thing might become problematic, depending on the asset).
If you find this annoying, it can be turned off when you right click on the node you're building, select Type Properties, and turn off “Check External References”.
J.C.
J.C.
John Coldrick
- pbowmar
- 7046 posts
- オフライン
Also, when you use CHOPs, every CHOP by default references /obj in the Export Prefix (common tab) which often causes many many warnings with CHOPs.
Even if you use `oprelativepath(“.”)` in there or something like that, it still catches it and gives you an warning.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- Sealth
- 50 posts
- オフライン
- pbowmar
- 7046 posts
- オフライン
- DevoStevo
- 35 posts
- オフライン
