Optix denoiser doesn´t seem to work
   1780   0   1
Hi all,
I´m working with the steam indie version and installed the Optix denoiser via the download and restarted houdini. The denoiser button is active in the render view but on the “Karma” node I get an error like this.
Warning: Problem while synchronizing child node:
Warning: Unknown channel(s) “denoiser, denoise_usealbedo, denoise_useN, denoise_useGl, image_artist, image_comment, image_hostname, image_exr_compression, image_dwa_compression” converted to spare parameter(s).
On my previous installation (non steam) the same setup worked well. It seems like it doesn´t recognize the denoiser. Is there a clue you can give me or a place I could look at? Even obvious ones
Thank you for considering,
Christian
