Hair Generate question
   1776   2   0
Good day. As you see in the attached image, the generated hair fibers along each guide appear to be exactly the same length, ending a strand at a very flat ending, which looks really unnatural.
Am I missing something? Is there a way to vary the length of the fibers per strand? I don't see it.
Thanks for any help.
lor
Are you using the hair shelf tools? If so, dive into your Hair Generate node and add a Guide Process. Choose Set Length and Randomize, then tweak to get the look you want.
So simple. Thank you Brian.
