Environment Map
   1491   2   1
I can't seem to find any parameter on any of the Solaris lights that has a parameter that lets you use an environment map file like you can with obj context lighting.
What's up with this?
We have to do it with shading?
スタッフ
In LOPs, an environment light is added with the Dome Light LOP. You can set the envmap in the Texture parameter.
Aye...I knew it would be something like that...passed right over it so many times.
Thanks for the heads up.
Having a forum like this for even the simplest things is very helpful.
I might have figured it out if I only walked away for an hour and did something else, then come back.
But you just saved some time for me.
Edited by BabaJ - 2021年10月29日 15:05:13
