Karma cryptomatte data doesnt load in Fusion
2711 2 1-
- DanielCardin
- 9 posts
- オフライン
Hi, I have noticed that when I use mantra, the cryptomatte data in my exr files are recognized in Fusion Studio and can be used by their cryptomatte tool. However, when including a cryptomatte pass using Karma, I get an image for cryptomatte but somehow the actual data is not present. Fusion gives an error saying that it "failed to read layer/index/channel information for layer: 'CryptoObject'" Does anyone know why the functionality is not the same between Karma and Mantra?
- goldleaf
- スタッフ
- 4258 posts
- オンライン
Hi, so we had someone internally open an EXR out of Karma, and the Cryptomatte pass displays correctly in the viewer, though the node throws a Lua error (which seems different from the one you described). So it's hard to tell if this is a bug in Fusion's Crytomatte plugin, or if it's a bug with Karma.
If you can put together a hip file showing the Karma/Mantra behaviors and log a bug, that will help us to track the issue (and better determine if there's anything we can do on our end).
I'm o.d.d.
- goldleaf
- スタッフ
- 4258 posts
- オンライン
I completely forgot, but this is likely because Fusion and/or Fusion's Cryptomatte plugin doesn't support the "newer" EXR format (it was introduced around 2013, I'm told).
You can append
Does this help?
You can append
--exrmode 0
to your husk command, either in the commandline or on the USD Render ROP go to the "Driver" tab and add the flag there.Does this help?
I'm o.d.d.
