I want to return an object that has been moved to its origin
   1272   1   1
Objects that were not at the origin,
I have returned an object that was not at the origin to the origin with the variable transform node-$CEX,-$CEY,-$CEY.
I would like to return the object to its original position.
on Transform SOP you can check Output Attribute to output the transform
and then use Transform By Attribute (Invert Transformation: On) to bring it back
or you can also use Match Size SOP that can do either of those operations
ts_translate_to_origin_and_back.hipnc (340.1 KB)
