Is it possible to align two sets of point cloud in Houdini?
1317 1 1-
- hinsunlee
- 39 posts
- オフライン
- tamte
- 9420 posts
- オフライン
If you isolate the same set of points from both pointclouds in the same order then Extract Transform SOP will give you the best fit rigid transform that you can use to align the full versions of pointclouds
If you have surfaced versions of those pointclouds you can potentially use Topo Transfer SOP to apply non rigid transform based in matching location markers
