POP particles moving between two points
   1516   2   0
Hi!
I have a little struggle with pop setup - I have a two points ("a" and "b") and I want to spawn a partilce in point A and moves to the point B and then dies, at the same time I want to particle that spawns in point B move to point A and then dies. I've manage to create basic setup(adding a pop attract with match method "point per particle"), but my problem is how to kill particles when they are close to the goal?
Thanks in advance!
Adding a "popproximity" node to the particle sim which will create a "nearestdist" attribute on each point/particle that can be read using a "popwrangle".....if its in range etc then set the attribute "life" = 0 or "dead" = 1 to kill the particle.
"Genius might be the ability to say a profound thing in a simple way." — Charles Bukowski
It works perfectly! thanks!
