Dop can't import animated attribtransfer node
   6219   2   0
I have a attribute transfer node with a animated distance threshold value so that the geometry acquire point color gradually through time (with a blend width), but it seems that dop can't import the value properly, is it an unsupported action?
I have attached an example file for your ref.
Thanks.
test.hip (105.2 KB)
you must check Use Deforming Geometry in RBD Object node to reload geometry every time step
ahhh…miss the obvious thing. Thanks a lot for the help!
Cheers.
