Rendered Animation is Trembling Too Much
   5127   6   4
I have a flapping bird animation. Obj is Bgeo format.
The rendered animation is a little too much trembling with cracked frames, Not Smooth.
I did Check the Allow Image motion Blur, Raytrace Motion Blue, Allow Motion Blur in Mantra>SAmpling. Still Not that smooth and blured image doesn't look crispy. How can I make my animated Obj look smooth after rendering.
Steve
オンライン
I dont understand your problem dude!
try to explain it little more clearly!
My rendered MOTION Of my animated Obj doesnt look smooth when i replay in MPLY. Frames Look Trembling & Crackking.
Thanks for your response.
Hope to hear more.
Steve
hip files or video makes it so much easier to help. Probably your motionblur settings aren't correct.
Drive, monkey, drive!
オンライン
the velocity values could be to high…(use the trail sop, and decrease the velocity value).
Erik_JE
Can you help me further with details. I am a biginner.
How the Hip Files and video make it easier ?
Can you explain more please. Thanks.
Steve
What Eric means is, provide us with a rendered movie so we can see what the problem is with the motion blur and a sample hip file (a saved houdini scene file which produces the error). That way we can check your settings and correct it where needed.
Available for new projects
