flip solver and velocity source question
   6674   2   0
I have an fliptank with container.
I have created velocity with source volume node but it seems like it only works when it is birthing new particles.
I just want to use that as velocity source (not to emit more extra flip particles)
How would I set-up a velocity volume that affect only existing flip particles ?
HELP!
sim_liquid_v03.hip (1.3 MB)
In my understanding in order to have a better control of a custom velocity filed you need to create one in DOPs or you can use sop solver inside DOPS to change your current velocities with a vector field, the one on the source are going to affect mostly the birthing particles.
You could take a look on the Peter Quint videos or the Solver Masterclass on the tutorial session to have a better understanding how it works.
I hope that helps.
Check out the pump shelf tool - this allows you to set up a source that just affects velocity without emitting new particles.
Peter Quint
