Point instancing with groups broken? (SOLVED)
2322 3 0- Dageris
- 95 posts
Hi. I have recently encountered a problem with instancing while working on a project. When I try to instance objects to a group of points it will either not work, or as in this example file not instance to all the points in the group. This has worked for me fine in the past, but now it doesn't seem to be working. I'm using the latest production build. Here is an example file. I appreciate any help you can give me.
Edited by - 2012年8月9日 12:59:40
- 8633 posts
object merge expects Primitive group if any
so if you put point group there, houdini imports just primitives with all points belonging to that group, therefore it is ignoring few points in your group
instead of specifying group in Object Merge, leave it empty and use Blast SOP to keep just points of your group
- Dageris
- 95 posts
- Dageris
- 95 posts
