I have been working my way through the scripting section of the user guide. I am learning alot andhave become completely fascinated by the possiblities..
I transcribed the tcl example code into a text document and when I source it in the tcl console the canvas draws but nothing else does.
I created a cop network in houdini and selected it before I ran the tcl command for the hscript prompt. I tried double clicking on the cop network after the tcl console appeared no luck..
How does the cop network information get passed to the tcl script?
User guide tcl example
7156 3 1-
- todd dufour
- 48 posts
- stevenong
- 1634 posts
Hi Todd,
The following links should help:
http://www.sidefx.com/forum/viewtopic.php?t=227 [sidefx.com]
http://odforce.net/forum/index.php?act=ST&f=15&t=456&s=70bb5e5646c097dc26f8069a11dea9d1 [odforce.net]
Good luck & have fun!
Cheers!
steven
Cheers!
steven
- edward
- 8068 posts
- オンライン
Perhaps the problem is that the example in the User Guide hasn't been updated to use the new COPs v2. It looks like it is using old cops. To fix the script to use the new COPs v2, you first need to replace /comp with /img. After that, change the get_start_range and get_end_range procedures to this:
proc get_start_range { copname } {
hscript set tmp=$copname
set start
return $start
proc get_end_range { copname } {
set end
return $end
The cop information is derived from the hscript command (as in the above calls to the hscript command).
set start
return $start
set end
return $end
- todd dufour
- 48 posts
I think that might be it… At some point yesterday I figured out that I needed to change the /comp to /img but I was still having trouble with the variable being read in the get_start_range procedures… I am at work now and do not have any access to houdini, but when I get home tonight I will try your changes…. I am rather sure that will work… Thanks. I was getting quite frustrated…
Todd Dufour
Life is as long as it is short.
