Houdini crash on windows 8 [Solved]
   20619   12   3
build 12.1.185
Windows 8 pro
16gb ram runs on 2400mhz X.M.P profile
3770k,GTX570.
Every time using Parameter windows in Houdini.
Houdini getting stuck and I must kill it from running.
(cant save project in the way)
to get error message I put pc to sleep and wake it up.
The error message running on loop on the Houdini Console:
“NT_GeneratorThread::queueEvent event queue full. Event dropped.”0
Edited by - 2013年1月19日 16:25:31
If you're using Nvidia drivers 310+, try using 306 instead. 310+, Win8 and Houdini seem to have issues with periodic freezing.
Thank you Mark!
I changed from display driver build 310.90 to 306.97
So far, work as usual with no special errors.
J.
yes!yes!yes!thanks!
I think forum moderator must create and stick solution about NVidia Drivers.
Just on 1st page in Technical Discussion we can see at least 3 topics
オンライン
There have been a few threads in the forum about it, and I did put in on the system requirements page a few weeks ago but I guess people don't read that.
http://www.sidefx.com/index.php?option=com_content&task=view&id=415&Itemid=269 [sidefx.com]
Stickied!
Chris McSpurren
Im running houdini 12.1.188 on win7 with Nvidia 306.97 drivers and am getting the NT_GeneratorThread issue sometimes… should I go to the latest drivers?
The newest 320.00 beta driver has resolved this problem, so any version in the 320 series will work properly with Houdini on a GEForce card with Windows 8.
As this is a beta driver, you may wish to wait for a WQHL driver (or at least a non-beta driver).
FWIW,
I've been plagued with crashes in window 8. even with the 306 driver and the newest beta.
I believe my problem is I have two graphics cards, even though they are the same ones NVidia 580. I have three monitors, one is a cintiq
Oddly enough I was able to get to work for a day, but I can't get the latest build of 12.5 running.
I'm going to pull my second card and see if that helps. I imagine it will.
Odd that this happens in 12.# builds.. I've had this configuration for awhile and 11.# worked fine
Any thoughts on the two card support?
Do you have all monitors driven by the same card, or split between the two? Also, is there a crashlog generated in your temp directory that you could post?
two monitors on one card, the cintiq on the other.
Crash report from keno; Houdini Version 12.5.376
Traceback from Thu May 02 10:32:26 2013
Caught signal 11
+0x6fa08845
+0x739e721c
+0x739efff4
+0x739d0a17
+0x739d1bc6
+0x739bde8b
+0x6dcd4c4e
+0x6dcd4dd8
+0x6dcccfdc
+0x6dcd4c4e
+0x6dcd4dd8
+0x6dcccfdc
+0x6dd80e4d
+0x6dcd4c4e
+0x6dd853a4
+0x6dd30b75
+0x6dd30f3e
+0x6dd310fa
+0x6dd312b2
+0x703d3364
+0x6dd30f1f
+0x6dd310fa
+0x6dd3119a
+0x6dd14c10
+0x6ef0ae2f
+0x6ef0b3d0
+0x40002fbb
+0xcc83167e
+0xcef13501
was that helpful?
not that it is a full solution, but I pulled my second graphics card and now I have no problem opening Houdini.
Just not as fun to lose my third monitor.
It would be great to be able to have it work again like it did in 11.##. with that version I was able to run with multiple cards A o K.
-k
