make project
6880 8 1-
- zafar
- 7 posts
- zdimaria
- 390 posts
- zafar
- 7 posts
- zdimaria
- 390 posts
so you could have a directory like this-
myproject
myhipfile.hip
-geometry
-geofile.$F4.bgeo
-textures
-mytexture.tif
-renders
when i bring in geofile in a file sop, i can point to it like this
$HIP/geometry/geofile.$F4.bgeo
$HIP turns into the path where the hipfile is saved. this way when you move the entire folder ‘myproject’, all of the references to files and textures still work.
when you load in a texture, you similarly would use $HIP/textures/mytexture.tif
and if you wanted to write out renders, you could write $HIP/renders/output_$F4.exr
when you click on a file button, on the left of the window that pops up, houdini makes a link for $HIP so you can easily access the correct directory.
hope that helps to make more sense.
myproject
myhipfile.hip
-geometry
-geofile.$F4.bgeo
-textures
-mytexture.tif
-renders
- zafar
- 7 posts
- SreckoM
- 381 posts
- オンライン
Yeah I think Ari confused a lot of newbies with this.
That is not related to Houdini, he was using Apple script to create project structure. And than he was using that structure within Houdini. it is like you manually create project folder, and inside that create other folders you need … Than open Houdini and save scene and other assets in those folders. There is no something like that in Houdini. Of course not that you can not make something like that with Python.
- zafar
- 7 posts
- zafar
- 7 posts
Apple script to create project structure, is shown on lesson three from sidefx how they do it. is from lesson 3 mean M03 from houdini can someone from the Houdini help out you can see attachment above why tech lesson and not show how is made. on apple desktop from training is day H12…..apps how you create that
many thank
zafar
many thank
zafar
- rspell
- 7 posts
