I just want to share an interesting observation. Recently I generated about 100m particles (using the usual seeded technique), merged them together and tried to render it (using a delayed load procedural to save as much memory as possible).
Now, my render consumed about 50GB of memory (I shot that one down), then I tried to remove the particle system primitives (I had one for each seed), so at the end my files contained only points. This time mantra rendered it with using less than 10GB (!) of memory (it was 5-6GB if I remember correctly).
I was aware that mantra doesn't need the particle system primitive anymore to render particles, but I didn't know about the memory consumption implications.
cheers,
imre
ps.: The fact that it can render 100m particles using only 6GB – mantra _rocks_ big time.
note on memory usage when rendering lots of particles
4081 9 1- riviera
- 1694 posts
Imre Tuske
FX Supervisor | Senior FXTD @ Weta FX
qLib -- Houdini asset library
http://qlab.github.io/qLib/ [qlab.github.io]
https://www.facebook.com/qLibHoudini [www.facebook.com]
- jparker
- 295 posts
- igou
- 102 posts
thank for share
I just have a question that after I delete particle system(use delete SOP and keep points) those points will be can't render with uniform volume ( I want render for spray )
maybe I should use other shader for render spray? any idea will appreciate
thanks!
iGou
thanks!
iGou
Edited by - 2013年6月5日 10:53:09
- jpparkeramnh
- 178 posts
- jpparkeramnh
- 178 posts
- igou
- 102 posts
Hi Jpparkeramnh:
Thank you for your advice! Sorry that I don't know much about Lighting Model. The way I have is to first create a VopMaterial in SHOP, then create a light model and connect it to Surface output (as the image below). However the result is looking weird… may I ask for more information on the settings of materials please?
Thank you for your time
Edited by - 2013年6月7日 22:08:05
- jpparkeramnh
- 178 posts
You should modify opacity with another VOP, like a constant or noise.
Generally points don't look good large and up close, and the answer is usually to generate many many more of them so that the individual points are no larger than a few pixels on-screen. This way they all average together to create a more complicated look. The sum is greater than its parts, as they say.
- jpparkeramnh
- 178 posts
- igou
- 102 posts
- riviera
- 1694 posts
jparker
Points as particle systems actually render as spheres by default, whereas without the particle primitive they are simply points. That's my guess as to why they took so much more memory.
-Jon
Hey, thanks, that's good to know…I'll check this out as soon as my time allows.
cheers!
Imre Tuske
