Creating parameter UI in volumevop from vex code
2205 5 0- Niall Flinn
- 4 posts
I'm starting to experiment with hand coding vex to manipulate volumes, and it seems like there are a few different ways of doing it. The approach I'm working on at the moment is to create a volumevop, dive in, plug a couple of nodes together in there, then examine the resulting vex code and use that as a template for my own code.
This is generally working fine: I can modulate the density using noise( P ) and see the results in the viewport. However, I can't seem to get my script to generate any UI for parameters. I have the following pragmas at the top of my script:
#pragma export testParm all
#pragma label testParm “Test Parm”
#pragma range testParm 0 1
… and the function definition specifies a default value:
float testParm = 0;
… but all I get is the default UI, with no field, label or slider for my parameter.
What am I doing wrong? Surely I don't need to “manually” create the UI? It seems that the pragmas are there to specify the UI from within the script.
Niall
float testParm = 0;
Niall
- circusmonkey
- 2624 posts
- Niall Flinn
- 4 posts
- circusmonkey
- 2624 posts
With a Volume VOP or any VOP type context you create the interface panel from the attributes contained within. ie create a parameter or MMB on the input of the vex node inside the VOP and promote parameter .
Pure vex code wise I am normally in the otl context , where you can make a pure vex type operator. Post a scene file up and lets see where your at .
Rob
Rob
Gone fishing
- Niall Flinn
- 4 posts
- circusmonkey
- 2624 posts
I have taken a look , interesting approach. I must admit its a workflow I have never considered as to me the VOP context operators by default build the interface from the vex nodes inside. I do believe you could use a Vex node inside the volume vop if you are more comfortable scripting it.
From a raw scripting approach I would do the following in Houdini .
File > new operator type > select vex type and from the drop down select geometry type. name your new otl, Now you will have a pure vex operator OTL that you can use repeatedly.
See the attached file for an example. I have left the VOP way of doing things and a script version .
Gone fishing
