I have recently purchased a Tesla K10, in the belief that it will dramatically speed up Pyro and fluid simulations.
I have 3 questions:
1. Do you need a Tesla AND a Quadro as asking around about how to get the Tesla to work with Houdini has suggested, or can it work alone to speed up sims?
2. Does it help speed up other dynamics or just Pyro and fluid?
3. If it is possible to use just the Tesla, how do I implement this?
Yours,
A keen noob,
5DN.
PS: although I know if this is probably obvious, I have another, not very good Nvidia card that runs my monitor.
Tesla with Houdini 12 functionality
7752 15 1-
- 5DN
- 152 posts
- anon_user_37409885
- 4189 posts
Not specific to the Tesla but may be of use;
1. Houdini currently uses 1 card for OpenCL
2. OpenCL is enabled for specific nodes. Searching the documentation you get below, but may not be comprehensive.
Gas OpenCL dynamics node
Gas Stick on Collision dynamics node
Gas Disturb Field CL dynamics node
Gas Advect CL dynamics node
Gas Project Non Divergent Multigrid dynamics node
Gas Combustion dynamics node
Smoke Solver dynamics node
Pyro Solver dynamics node
3. You can choose your OpenCL device with the environment variable
HOUDINI_OCL_DEVICENUMBER
HOUDINI_OCL_VENDOR
HOUDINI_OCL_VENDOR
- 5DN
- 152 posts
MartybNz
HOUDINI_OCL_VENDOR
Understood the rest but this is beyond me as a noob… searched help to no avail. Could you link me to some documentation about how to do this or post here if not too much trouble.
Thanks.
PS: i noticed you've helped me a few time. thanks. i was wondering if as a night owl you being on the other side of the world is a bonus for your help!?
- 4189 posts
In the Houdini terminal/command line tools you can find out information on all the available variables:
typing ‘hconfig -H’
Gives a descriptive environment variables. This one is probably the most significant:
In the case of multiple OpenCL devices existing of the type specified by
HOUDINI_OCL_DEVICETYPE, this variable selects which of these devices to
use for OpenCL processing. For example, with a computer with more than
one GPU this allows selection of a GPU other than the default for OpenCL.
So you would set it to either 0 or 1 I believe. On OsX you put this into the Houdini.env file as.
HOUDINI_OCL_DEVICENUMBER = 1
Then in Houdini go to help/about Houdini, scroll down. It should say which device is being used for OpenCL if I recoil correctly- OsX doesn't yet support OpenCl so I get ‘OpenCL is not supported for this system’
Hope that helps.
typing ‘hconfig -H’
Hope that helps.
- 5DN
- 152 posts
I'd tried your advice and loads of alternate methods I can think of to no avail.
I get error message:
OpenCL Exception: No OpenCL platform found. (-32)
Tried putting:
HOUDINI_OCL_DEVICENUMBER = x
into Houdini.env file where i've tried 0-4 as x
Same error message always.
I'm beginning to worry my Tesla may not be working properly
It does say its fine in Windows device manager though… does this mean its definitely ok?
I also have tried using the nVidia control panel to disable the attempted use of CUDA on my Geforce 210 and still the same message.
It says there's a Tesla there though so that cheered me up.
I did install a bunch of other crap on my computer a few days ago to try and test the Tesla (Visual Studio, somebenchmark stuff,etc.) and wondered if any of that could have messed up my system. I'm trying to clean it out now.
Thanks in advance for any more help
Nick.
Tried putting:
Nick.
- 4189 posts
- johner
- 826 posts
5DN
Hmm, you get this error even when no environment variables are set? It could be a driver problem, but by default the Nvidia drivers should include an OpenCL driver. Your regular Nvidia video card should at least show up in the About Houdini | Details box as an OpenCL device.
Have you tried any other OpenCL-based software like LuxMark?
http://www.luxrender.net/wiki/LuxMark [luxrender.net]
- 5DN
- 152 posts
johner5DN
have not tried that software.
if there are no default variables its automatically OpenCLs the Geforce 210….
any ideas?
- 5DN
- 152 posts
- malexander
- 5298 posts
- オンライン
Did you check the Windows Device Manager to see if it's being recognized, or has an issue (yellow (!) icon on the label). I'm assuming that you have the aux power connectors plugged in and have a power supply that's large enough to power your system with the Tesla K10 in it.
Edit: also make sure the Tesla driver installed correctly.
- 5DN
- 152 posts
twod
No yellow icon in device manager.
I had one 8-pin power connected. Some documentation said I only needed that.
Do I need to connect the 6-pin too?
I have an 800W PSU, which a computer specialist said was enough.
What has led me to believe its broken is two missing gold bits on the PCI slot…..
i'll upload photos…..
and there is a photo of something that i couldn't discover what it was….
thanks…
nick
- malexander
- 5298 posts
- オンライン
- 5DN
- 152 posts
- 4189 posts
- 5DN
- 152 posts
- 4189 posts
Try Unduntu 12.04:
http://www.ubuntu.com/download/desktop [ubuntu.com]
Nvidia drivers - use the Linux option!
http://www.nvidia.com/Download/index.aspx?lang=en [nvidia.com]
That worked for a GeForce - should be fine to test with for Telsa I'm guessing.
And of course Houdini on Linux! Installation faq:
http://www.sidefx.com/index.php?option=com_content&task=view&id=1207&Itemid=273 [sidefx.com]
